26-07-2020 #21
It has a belt drive which i believe is a 1.5-1 ratio. I very much doubt I would be trying to drive this at anywhere close to it's max output and I can easily overcome most of the downsides of this just by reducing my DOC and better calculating the speeds and feeds. Hell, if i can get 30% of the normal max power it would turn this from a beautiful giant doorstop into a machine again!!
To be honest I am going to have to figure this out as i go along, it is deeply outside of my comfort zone. I work with big AC all the time but DC, of this kind, is a mystery to me (but getting clearer as i look into it more). Getting this running is first on the list so I will give this a go and put fuses into the line so i don't do any damage. I have a few different caps i can use and i can trial a few different configurations to see how it is effected. Then I will further look at the control side, when i can get this to work.
I will try this too and let you know how it goes, so long as i don't do any permanent damage I am up for trying anything!
First things first though, i will have a bit of time tomorrow to do some measuring and calculations then will see where I am!
Thank you for all your help.
Mort
Boxford VMC 300 Sirel Spindle Drive and motor
By Joe in forum Boxford Vertical MillsReplies: 0Last Post: 12-08-2015, 07:46 PM -
Spindle encoder ideas needed
By Boyan Silyavski in forum General ElectronicsReplies: 4Last Post: 10-08-2014, 01:31 AM -
Driving a Chinese spindle VFD from mach3
By jcb121 in forum Tool & Tooling TechnologyReplies: 5Last Post: 14-08-2013, 10:35 AM -
dc motor - spindle / shaft drive
By dsc in forum Spindles & Drive MotorsReplies: 21Last Post: 01-06-2013, 10:42 AM -
RFQ: Need ideas (or someone to make) a widget to couple motor shaft to M8/M10 threaded rod
By HankMcSpank in forum Projects, Jobs & RequestsReplies: 11Last Post: 17-04-2013, 07:35 PM
