    Thank you for your reply you have cleared up a few of the questions I have.
    I have ordered the motors drivers will have till next month to buy more bits.
    I have some more questions if that's ok
    1.which controller do you recommend I would like one that's able to run on windows or a MacBook Pro. I believe ethernet is the most stable way to run but I am not sure.
    2. Can you point me in the right direction to a circuit diagram for the power supply.
    I will start a build log once I start
    Thank you again
    Albert
    Quote Originally Posted by bigal999 View Post
    I
    Thank you again
    Albert
    Joe on here as done a nice vid
    https://www.youtube.com/watch?<br />...zD30sZjtp_VyqYClick image for larger version.
Name:	power supply.JPG
    I strongly advise you to hold off buying anything untill you know exactly what your buying and why.! . . . Rushing to buy is THE single biggest mistake new builders make and perfect way to turn low budget into wasted budget.
    What have you ordered.?
    Yes Ethernet is the way to go, avoid USB. The controller I'd use is a UC300ETH but this requires a good breakout board to get the best from it which adds to the cost. However the AXBB-E is a good choice if you don't need lots of I/O as it's got a built in breakout board in a nice neat little package.
    I'd run both these from UCCNC rather than Mach3 but both will happily work with either.
    Follow Clive's link to Joe's setup.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Dean,
    I've seen this said a lot but I think what a lot of your seasoned CNC guys forget is that beginners, myself included, have no idea how many IO's they are likely to need? Or really what they're even needed for? I'm kinda guessing homing/limit switches and the like but can't think of much else.
    If you get the chance (and I know you said in another thread you were very busy at the moment) could you just do a post about IO's and what the main needs for them are. I think it would help a great deal of people, the OP included.
  1. First Cnc Router. Looking for advice please.
    By Timatronics in forum Machine Discussion
    Last Post: 20-09-2019, 03:17 PM
  2. BUILD LOG: Need advice please on 3D CNC Router Kit
    By SACarver in forum DIY Router Build Logs
    Last Post: 31-03-2019, 04:50 PM
  3. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  4. Replies: 4
  5. Advice on which cnc router
    By Xenophya in forum Milling Machines, Builds & Conversions
    Last Post: 08-10-2012, 11:25 PM
