28-07-2020 #2
The term 3018 is a generic sizing term common amongst lots of Chinese mini routers, but I'll go with the best info I can grab off Amazon as to a likely configuration.
If the motor is making a noise but not turning then that does/could sound like a fault between the motor driver and the motor (the motor has two pairs of coils - hence 4 wires - if one wire/coil fails then then motor generally will make a noise without substantially turning).
From what I can see there's a motor driver board on the gantry that each of the 3 motors plug in. With the machine de-powered, swap the wiring/plug for the motor that's at fault with another that works and re-test. If the problem follows the wiring (i.e. the donor motor is now faulty) then the problem likely lies with the controller board, otherwise it's likely to be the motor or the wiring. If the motor/wiring then you need to eyeball the cables, connectors, make sure everything is pushed home.
If the problem is localised to the board (i.e. swapping the motors makes the new donor motor fail) then it could that on the board under each axis drive there's a miniature rotary potentiometer that sets the current for each motor axis (i.e. 3 in total for 3 axis). You could eyeball these and try tweaking the appropriate channel to increase the current, but I'd be surprised if these have substantially moved from OEM/build calibration.
CNC 3018 Pro - Z Axis Stability improvement idea..
By richardsenior in forum Chinese MachinesReplies: 8Last Post: 25-10-2020, 09:55 AM -
3018 3 Axis Mini DIY CNC Router ONLY £125 with free shipping !!!
By Lee Roberts in forum Marketplace DiscussionReplies: 6Last Post: 09-01-2020, 09:00 PM -
3018 problem
By bazbalz in forum Machine DiscussionReplies: 8Last Post: 17-12-2019, 12:58 PM
