    Quote Originally Posted by John11668 View Post
    I suppose we all have differences in the way we need to set up . I had not considered this when I originally posted . And it is not surprising that the woodcarvers have different needs to The Heavy metal brigade
    Mine is a milling machine of course.
    And it had not occurred to me either that having a profiling tool run past zero (obvious once pointed out) could be useful in milling an external profile too, but I suppose that applying an offset overcomes that need.
    My next need is to allow for a touch of backlash on my Z motion . Its not much but I would like to figure out how to apply it .
    I have ball-screws on X and Y but for my Z axis I am driving the quill through mechanical gears with a 6/1 reduction. As I say it is not a massive amount as there is little wear but If I understand how to cater for it it will assist my next project.
    Will backlash be a problem in Z as I would have thought the weight of the spindle would always keep the tool at the lowest position possible thereby eliminating backlash?
    Quote Originally Posted by ngwagwa View Post
    The quill has a return spring , a bit like a pedestal drill but in an exercise the cutting depth is often increasing so backlash wont be a problem there. But lots of exercises where the quill is being driven up and down frequently so lost motion in each direction in that case . I am presuming if you enter a backlash figure , then a number of steps will be discounted before the Display registers movement. Is that so?
  1. mach3 soft limits
    By Daveo in forum Control Hardware & Systems
    Last Post: 25-06-2020, 05:24 PM
  2. Lichuan "Easy Servo" closed loop stepper question
    By Voicecoil in forum Stepper & Servo Motors
    Last Post: 09-10-2019, 09:33 PM
  3. "Hacking" and "Modding"
  4. Setting up "System 45" 3 axis unit by DIYCNC
    By StevenT in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 03:22 PM
  5. "Racks" VS "ball screw"
