28-07-2020 #6
[QUOTE=Doddy;119103]I'm not at my machine at the moment, and barely remember this - but can you not set the axis to, after homing, traverse to a fixed offset (within the working envelope, and within the desired soft limit). E.g. home to zero, move to 12, with a soft-limit of 10?
Just tried that Doddy and when the machine backs off after going home it only goes to the softlimit value - so would work if back off and softlimit was set the same.
John. Softlimits prevent machine going past the limits to prevent a crash and (on my set up at least) home switches don't limit movement when jogging.
If you look in configuration - Axis Setup for each axis there is a back off units box - set this value and when homing the axis will move back by te set value - make sure you set it positive or negative s required.
Softlimits will reduce the size of the working area - I have X backoff as -3 and softlimits at 0 so I don't lose anything.
Hope this explains it ?
mach3 soft limits
By Daveo in forum Control Hardware & SystemsReplies: 12Last Post: 25-06-2020, 05:24 PM -
Lichuan "Easy Servo" closed loop stepper question
By Voicecoil in forum Stepper & Servo MotorsReplies: 15Last Post: 09-10-2019, 09:33 PM -
"Hacking" and "Modding"
Setting up "System 45" 3 axis unit by DIYCNC
By StevenT in forum LinuxCNC (EMC)Replies: 2Last Post: 15-10-2014, 03:22 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM
