    Quote Originally Posted by ngwagwa View Post
    Correct re purpose of softlimits ie prevents crashes at end of travel.
    Whatever back off you set you don't need to alter the gcode as Zero is still zero. So to clarify on my machine with a back off of minus 5mm after machine has been homed the DRO will display -5mm when displaying machine co-ordinates.
    But doesnt a backoff of -5 take you beyond the home limit presuming you are homing in negative direction from an x positive position on the table .??
    Quote Originally Posted by John11668 View Post
    As I said earlier make sure you have the right direction for the back off - my home is far right so moves postive in X to get home, therefore I back off negative.Big noise and you got it wrong!
  1. mach3 soft limits
    By Daveo in forum Control Hardware & Systems
    Last Post: 25-06-2020, 05:24 PM
  2. Lichuan "Easy Servo" closed loop stepper question
    By Voicecoil in forum Stepper & Servo Motors
    Last Post: 09-10-2019, 09:33 PM
  3. "Hacking" and "Modding"
  4. Setting up "System 45" 3 axis unit by DIYCNC
    By StevenT in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 03:22 PM
  5. "Racks" VS "ball screw"
