As you say Neale it is not at all intuitive to begin with, and I dont believe I have seen a clear explanation in the manuals . ( and some of the videos are even less helpful)
I think I have got it now though.
So by homing and setting soft limits you are defining the extremities of the working area, within which you will place your job.
You then choose a point on your workpiece which you will define as 0,0,0 for you starting point, traverse your tool to that point and you will then set the work coordinates to zero on all axes.
The G code routine will then move the tool in whatever positive or negative directions are needed to complete the work.
I suppose it becomes particularly clear when doing say an engraving job where conventionally you will set z=0 when the tool is touching the surface, then any movement to Z negative involves a cutting depth and movement to Z positive gives a clearance for tool repositioning.
mach3 soft limits
By Daveo in forum Control Hardware & SystemsReplies: 12Last Post: 25-06-2020, 05:24 PM -
Lichuan "Easy Servo" closed loop stepper question
By Voicecoil in forum Stepper & Servo MotorsReplies: 15Last Post: 09-10-2019, 09:33 PM -
"Hacking" and "Modding"
Setting up "System 45" 3 axis unit by DIYCNC
By StevenT in forum LinuxCNC (EMC)Replies: 2Last Post: 15-10-2014, 03:22 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM
