29-07-2020 #18
Hi Jazz and thanks for your response .
I dont think however you have quite clarified things for me.
So ignoring backoff for now .
I home to machine zero in all axes and the machine defines its position as 0,0,0
I have set soft limits X of 0 and 400.
Soft limits Y of 0 and 200,
and Soft limits Z of 0 and -50
So I have now defined a box 400x 200 x50 which is the envelope within which all work MUST be done .
We now come to the workpiece which I have to plant on the table completely within that envelope and clamp it. I have to bear in mind if I am doing an outside profile that I must consider the cutter and allow at least a cutter radius all round.
I am guessing that my workpiece origin or start point is defined somewhere within it , whether it is right hand end, middle, or wherever so I identify that origin, jog to it , and set all my work parameters to zero at that point.
So really it is only if I have placed my job wrongly and that the toolpath will stray outside the envelope that a soft limits alarm should arise .
Are you saying that it should arise prior to hitting the start button . or will it only arise when the work zero position is defined .
mach3 soft limits
By Daveo in forum Control Hardware & SystemsReplies: 12Last Post: 25-06-2020, 05:24 PM -
Lichuan "Easy Servo" closed loop stepper question
By Voicecoil in forum Stepper & Servo MotorsReplies: 15Last Post: 09-10-2019, 09:33 PM -
"Hacking" and "Modding"
Setting up "System 45" 3 axis unit by DIYCNC
By StevenT in forum LinuxCNC (EMC)Replies: 2Last Post: 15-10-2014, 03:22 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM
