A precise and detailed description of my own machine!
I love threads like this, I always learn a great deal myself and as I discovered when I took up teaching technical stuff to adults back in the 80s, there's nothing will show up the holes in your own knowledge more effectively (brutally at times!) than trying to explain things to someone else. I now need to swot up on the full details of G54, G55 and other relevant codes and exactly how LinuxCNC uses and saves them.
The difference between machine coordinates and work coordinates is, as Neale pointed out, a confusing one tro begin with but soon becomes one of those fundamental bits of knowledge you don't realise you never knew.An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
31-07-2020 #2Yes this confuses many people. Have you noticed that you can see the machine coordinates and the current G54,55 etc on some GUIs at the same time. In Linuxcnc you can turn them on and off from the view tab.. I now need to swot up on the full details of G54, G55 and other relevant codes and exactly how LinuxCNC uses and saves them.
Ie. If you have touched off your part ie X0,Y0 in G54 you will see the machine G53 at the same time completely different.
http://linuxcnc.org/docs/2.8/html/gc...es/offsets.png
http://linuxcnc.org/docs/2.8/html/gc...ordinates.html..Clive
31-07-2020 #3
Probably without knowing it you and many others have actually been using a WORK OFFSET in fact if you have been using 2. These being G53 and G54.
When you HOME your setting G53 ZERO which is MACHINE coordinate system and when you set WORK ZERO you're using G54 WORK OFFSET. Almost all controllers, Mach3, UCCNC, LinuxCnc, even industrial-grade controllers like Fanuc, etc use G54 by default and unless you specifically need to use a different OFFSET say for things like multiple vises with OP1 OP2 type setup or several Fixture Jigs which all have a ZERO point you don't need to know about them.
Most CAM packages are also set up to use G54 by default which is another reason why many users don't actually know they are using WORK OFFSETS.
If you have a large working area WORK OFFSETS makes cutting several different jobs say as in different materials or thickness very easy because of each Fixture as it's own ZERO.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
mach3 soft limits
By Daveo in forum Control Hardware & SystemsReplies: 12Last Post: 25-06-2020, 05:24 PM -
Lichuan "Easy Servo" closed loop stepper question
By Voicecoil in forum Stepper & Servo MotorsReplies: 15Last Post: 09-10-2019, 09:33 PM -
"Hacking" and "Modding"
Setting up "System 45" 3 axis unit by DIYCNC
By StevenT in forum LinuxCNC (EMC)Replies: 2Last Post: 15-10-2014, 03:22 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM
