    Does anyone know of a UK supplier of decent 1 and/or 2mm diameter ballnose carbide cutters for aluminium with a flute length around 10mm?
    I can only see their 1mm ballnose with a flute length of 2mm ?
    https://www.shop-apt.co.uk/ball-nose...d-carbide.html
    1mm with a 10mm flute?, I'll like to watch a video of you cutting with those... without swearing!
    https://www.shop-apt.co.uk/2-flute-l...ong-55hrc.html
    Long neck - not full length flutes. Don't know if that helps?
    I have tried those thanks but they tend to gum up when used on aluminium. I have found long neck but they are in the order of £25 each so was hoping to find some cheaper.
    For your entertainment here is a video of a 2mm tool cutting.
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 17 Hours Ago Has been a member for 8-9 years. Has a total post count of 486. Received thanks 81 times, giving thanks to others 26 times.
    Try looking for router bits rather than milling cutters perhaps?
    https://www.rennietool.co.uk/product...smart_campaign
    I bought some of these (but flat end) for a job I never did, so I can't tell you how good they are in ali.
    https://www.aliexpress.com/item/3296...14b32917ArcyeD
    These are brilliant for Aluminium, I've used 1mm up to 16mm, use the cutting data for YG AluPower and good flood coolant and they really shift material and also give nice surface finish when used on finishing passes.
    https://www.shop-apt.co.uk/3-flute-c...-uncoated.html
  1. Down cut carbide cutters
    By Leadhead in forum Marketplace Discussion
    Last Post: 22-02-2016, 03:07 PM
  2. FOR SALE: Dormer Carbide Milling Cutters
    By ricey3 in forum Items For Sale
    Last Post: 14-01-2016, 12:25 AM
  3. Carbide cutters
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 24-01-2014, 10:57 AM
  4. Single flute carbide cutters
    By Jonathan in forum Tool & Tooling Technology
    Last Post: 11-11-2011, 06:48 PM
  5. Cheap carbide cutters
    By HiltonSteve in forum Tool & Tooling Technology
    Last Post: 30-07-2009, 08:03 PM
