01-08-2020 #11
Hi would it be better if I built the sides from 10mm or 15mm aluminium and how wide would it have to be.
I could use the profile for bracing across the bed.
As I can not see how to attach the rails to the profile as the hole spacing is 30mm and the profile is 40mm
Albert
NEW MEMBER: Hi from Albert
By bigal999 in forum New Member IntroductionsReplies: 0Last Post: 25-07-2020, 09:05 AM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
