Albert, this is why I said Step #1 is a plan. Do a accurate drawing of the machine and it will tell you all the sizes.
If using the design like picture Kit posted then 15mm plate as a minimum for the gantry sides. The height of the sides will depend on the clearance and Z travel you require, again drawing a plan of the machine will help with all this.
Don't be tempted to skip the steps or design on the fly as it's a recipe for failure and will cost you more money long term.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
NEW MEMBER: Hi from Albert
By bigal999 in forum New Member IntroductionsReplies: 0Last Post: 25-07-2020, 09:05 AM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
