Albert,
You'll probably get a dozen different answers to your question depending on what people are familiar with and that partly depends in which decade they first started using CAD themselves.
CAD is for drawing the object you want to make. You then need CAM (Computer Aided Machining) software for generating the G-Code that the machine will read in order to make the real object. The following packages include both elements.
The high-power budget option is Fusion 360 which is free for hobbyists to use but is a fully professional, up to date 3D package with all sorts of capabilities you would never have imagined wanting before. Some people find it easy to get on with, others find it over-complex for their needs. I would definitely recommend you try it out since there is nothing comparable in terms of capability or bang for buck. If you get on with it OK then I doubt there is any other better option for a budget-conscious amateur.
For several years I've been using CamBam. You have to pay a one-off fee for it but that gets you upgrades for life. This does not have the rendering, animation and other bells and whistles of F360 but is more of an old-fashioned (turn of the millennium) style 2D drawing package with CAM capability. The basic package can be greatly enhanced by adding a range of add-ons produced at no cost by the very capable and helpful user group on the software's forum.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
05-08-2020 #2
I would say Fusion 360 is your best choice because it's free and fully capable professional program from a High end software company with both good CAD and CAM capability's. Yes it's a complex program with high-ish learning curve but it's massively covered with lots of tutorials online and users willing to help on forums etc.
Email: [email protected]
Web site: www.jazzcnc.co.uk
NEW MEMBER: Hi from Albert
By bigal999 in forum New Member IntroductionsReplies: 0Last Post: 25-07-2020, 09:05 AM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
