06-08-2020 #11
if you are going to go steel route then look for 4 or 5mm wall box section 50mm will work but 60 or 80mm better. Make the base from box section with rails sat on the top face of steel and make the gantry from profile, I suggest using the "L" shape layout of profile as it gives good strength(Just search the forum you'll see it used often). To raise the gantry use vertical pieces of profile that bolt into the lower piece of gantry profile.
This will be a simple weld up and easy to build.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
NEW MEMBER: Hi from Albert
By bigal999 in forum New Member IntroductionsReplies: 0Last Post: 25-07-2020, 09:05 AM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
