07-08-2020 #11
Hi I have been doing so research and found some people use what they call epoxy granite to fill there box section and profiles. From what I can gather it is a mix of epoxy and fine sand. They say it helps limit vibration is this true.
Also seen references to epoxy leveling is this to get the cutting table level.
On the pc front should have a computer by the end of the month
Albert
NEW MEMBER: Hi from Albert
By bigal999 in forum New Member IntroductionsReplies: 0Last Post: 25-07-2020, 09:05 AM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
