10-08-2020 #11
Trying to work out my design but need some answers to get me started.
1. Y axis side plates if I use 15mm aluminium plate how wide will it have to be.
2. Y axis is 600mm wide can you give me an idea how deep the gantry plate would be if I used 15mm aluminium plate.
3. How deep would X axis plates need to be the length is 1000mm and would be 15mm aluminium.
4. If this costs out to expensive. Could I use steel plate and what thickness would I need.
Albert
NEW MEMBER: Hi from Albert
By bigal999 in forum New Member IntroductionsReplies: 0Last Post: 25-07-2020, 09:05 AM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
