14-08-2020 #16
For the gantry the easy and quick method is to use 2 pieces of 90x45 profile and fit them together to form an L section. Nothing else is required, job done.
You can bolt the gantry sides to each end of the profile . (you can tap the holes in the end of the profile to 12mm)..Clive
NEW MEMBER: Hi from Albert
By bigal999 in forum New Member IntroductionsReplies: 0Last Post: 25-07-2020, 09:05 AM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
