14-08-2020 #26
Yes, it would work but again not needed and all your doing is adding weight. All you need is a drop-down bracket from the top bearing plate which extends backward.
But like I said your design will work and will be strong enough so if you are happy to use that then go with it.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
NEW MEMBER: Hi from Albert
By bigal999 in forum New Member IntroductionsReplies: 0Last Post: 25-07-2020, 09:05 AM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
