    Hi fellows, I'm new here.
    I've checked some of your threads, and could probably contribute a bit.
    The machine was designed for wood, plastic, soft metalls,
    working envelope 200*230*65mm
    fancy solution (miiiinnnneee :) ))) of Z-axis - neodymium magnets + Teflon as the slides and polished metal plate. the force required to tear it off - 20kg, to slide it - 2 kg, works pretty fine, no backlash at all ;) .
    a bit of history in pictures, + work done so far.
    X, Y axis - built using hardened 300mm D=12mm Thompson rods,
    linear ball bearings, plastic bushings,
    tools used for the build - lathe, milling machine, drilling machine, digital calliper, common sense.
ID:	1103 Click image for larger version.
ID:	1104 Click image for larger version.
ID:	1106 Click image for larger version.
ID:	1107 Click image for larger version.
ID:	1109 Click image for larger version.
ID:	1110 Click image for larger version.
ID:	1112 Click image for larger version.
ID:	1113 Click image for larger version.
ID:	1115 Click image for larger version.
  2. Z-axis - neodymium magnets + Teflon as the slides and polished metal plate.
    Great idea (although be careful not to generate any steel or magnetic swarf)
    I wonder if it'd be possible to build a roller/ball slide using a similar technique???
    yes, it would be not a problem, but we would loose the main advantage - Simplicity:)
    Any way lets say that we use at least 10kg*cm motors and screws of about 4mm pitch - that means a reduction from 2*Pi*1cm to 0.4cm = 15 - which means for a perfect screw you'd have a 150kg moment of force, those 2kg required for friction will simply disappear.
    I'd place roller and magnet only where you need taking off and placing back the carriages.
    Oh - by the way my Mark 1 machine was MDF based router. I've made them like that:
    Looks like you have quite a bit of chatter going on from the looks of the engraving, too much unsupported railage. Totally mad and wonderful idea tho, love it.
    Jeff.
    well - that was 140 grams valentine greeting. Sad that this is now my Ex GF.
    but as Italians say never run for a train or a woman, next one always come.
    you haven't seen one Russian fellow' wooden CNC :)))) if you think that my idea is crazy :)
  1. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  2. Linier slide bearings - can they be adjusted?
    By craigrobbo in forum Rails, Guideways & Bearings
    Last Post: 10-08-2012, 02:52 PM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  5. FOR SALE: 25mm Linear Slide bearings
    By D-man in forum Items For Sale
    Last Post: 28-11-2010, 05:14 PM
