Thread: Vinyl lathe
    Apparently there is much interest i creating Vinyl discs by cutting on a lathe , rather than by pressing these .
    Does anyone have any info on lathes , the process , or the software?
    Asking on behalf of a family member who is into his Music.
    Put 'cutting a recording disc' into Google.
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 16 Hours Ago Has been a member for 8-9 years. Has a total post count of 490. Received thanks 81 times, giving thanks to others 27 times.
    Ooooh, now that sounds incredibly expensive. IIRC, there are some special "audiophiles" out there who really like to be parted from their money. I could almost be tempted to help them myself.
    Did that first Kit
    not a lot of info about the process or the machinery.
    As ever , collectors seem to be prepared to shell out fortunes for stuff which wouldn't interest me.
    I am guessing that master would be cut in Laquer from the music tape so I presume the process is an NC process. Then subsequent discs would be pressed in vinyl from that.
    I now hear that there are machine cut discs in Vinyl which I understand have far superior sound quallity. It is that process I am trying to find out more about.
    Quote Originally Posted by Muzzer View Post
    You may well be right Muzzer
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    https://thevinylfactory.com/features...r-own-records/
    The basic process predates NC, but I'm not sure if it's a process that could realistically be done using NC, given the frequencies involved.
    Moving the recording head could be done very easily using NC, but the actual cutting at any kind of productive speed, I'd doubt. It's the kind of process where an analogue process (i.e. a electro-mechanical system) will greatly out perform a fully digital process.
    I'd be searching to try and find out how the recording/cutting heads on the old school disc recorder heads work, like those in the link I found above. If you can create a working head, then the actual lathe part should be pretty straightforward.
    Personally I think the guys in that video are barking mad! But plenty of people think that of me so no problem. The most important thing to understand about the whole process of making gramophone records is that the only thing it has in common with anything anybody usually talks about on this forum is the the use of the word 'lathe'.
    The following is a memory dredge of stuff I learned a long, long time ago. Only the seriously geeky nerds should bother reading this.
    Mono recordings make a constant depth track that is modulated from side to side to record the music.The master disc is cut into shelac or something similar layered onto an aluminium substrate. In the old days of 78 recordings the radial inward speed which sets the track spacing was constant and had to accommodate the highest possible amplitude of signal. In later 45 and 33 rpm systems the recording engineer had control of the track spacing and could reduce it for quieter passages, thus increasing the recording time available on a side. This was part of the art being a disc cutting engineer.
    The master disc was then used to create positive mold masters (can't remember what they were made out of if I ever knew) which would be used to stamp the discs. Since the master was only ever used to make molds it would last a long time and could be used to replace worn out stamps many times over.
    Before the advent of tape recording you could go to your local music shop and record your own 78 rpm disc. The earliest recording my sister and I have of our mother singing is one of those. You can see an example of such a machine being used in the film 'The King's Speech'.
    When stereo came along the need was to have a single groove carrying two channels of audio and it's geometry had to be mono-compatible for existing players so the recording head has two electromagnetic solenoids driving the cutting tool along paths at 45 degrees to the disc surface, 90 degrees to each other, one for the left audio channel (L) one for right (R).
    There's a link below to a video that explains this idea using model aeroplane servos to move a model head.
    This produces an end result where the sideways deflection of the track is derived form the Left + right (L+R) signal amplitude divided by two and the vertical movement is left minus right (L-R) divided by two, the difference signal which depends on the pan position of the source. A mono player only recovers the sideways component, L+R for a satisfactory compatible output but the stereo cartridge has two transducers at 45 degrees like the cutting head.
    Off to the side for a moment, FM radio uses a similar idea to add stereo transmission to an existing mono system by transmitting (L+R)/2 voltage as the standard mono 'sum' signal and adding the (L-R)/2 'difference' signal as a subcarrier. Mono radios ignore the subcarrier but a stereo receiver recovers L and R by adding and subtracting the difference. (L+R)/2 + (L-R)/2 = L. (L+R)/2 - (L-R)/2 = R.
    Clear as mud?
    Kit
    https://www.youtube.com/watch?v=s62GfJEr6PI
  8. The Following 2 Users Say Thank You to Kitwn For This Useful Post:
  1. Anyone got a flatbed vinyl cutter?
    By andy_con in forum General Discussion
    Last Post: 06-11-2019, 06:55 PM
  2. For Sale: GCC SignPal PumaII CNC vinyl cutter
    By NickStockUCS in forum General Discussion
    Last Post: 29-06-2016, 12:27 PM
  3. CNC Vinyl Cutting
    By Leadhead in forum Workshop & Equipment
    Last Post: 24-03-2016, 09:09 PM
  4. Walnut Vinyl Wrap - Good one?
    Last Post: 29-12-2014, 02:53 PM
  5. Test of new vinyl cutter
    By evildrome in forum Tool & Tooling Technology
    Last Post: 17-01-2011, 12:25 AM
