02-08-2020 #1
I have a setup that uses 2 x 18650 3.7V 4000Mah batteries in series ( producing 7.8Vdc. Im trying to control a 6-9V dc miniature motor with 2 buttons 1 button to CW and the other to CCW
Ive been told that a L293d will work but ive blown up 5 so far
I think the problem is im imputing too high a current into the Vcc1 (pin 16) which calls for 5V (max 7) attached is a diagram i found with basic setup I would appreciate someone confirming the setup IF I REDUCE INPUT TO 5VDC
Also if i connected something to the end of the + 7.8v feed to reduce the current to 5V .
Im not electronics savvy so appreciate any help
Thanks Richard
Everything works in reverse
By Starday in forum Machine DiscussionReplies: 0Last Post: 15-06-2020, 04:11 PM -
Stepper direction problem, only one direction when + or - is called
By Leadhead in forum Machine DiscussionReplies: 1Last Post: 04-07-2017, 11:48 AM -
Dumb Reverse
By Leadhead in forum General DiscussionReplies: 3Last Post: 03-10-2016, 12:41 PM -
Reverse engineering
By mikewatch in forum Probing, Digitizing & ScaningReplies: 1Last Post: 13-04-2013, 10:20 PM -
Reversing motor direction in Mach3
By bruce_miranda in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 16-11-2008, 06:54 PM
