07-08-2020 #18
Doddy
im not using any breadboard etc im soldering directly to the L293d pins i dont physically have the space to have a breadboard
Ive been super careful to keep the heat down and not shorting with the solder ( between pins) that said the photo would not be clear enough
ive recreated with 5 no L293d and 3no lm708s and get identical readings and problems so dont think its a soldering problem
I dont understand why the power feed from 16 is looped thru push button + to pin9
is the drawing fundamentally wrong?
Everything works in reverse
By Starday in forum Machine DiscussionReplies: 0Last Post: 15-06-2020, 04:11 PM -
Stepper direction problem, only one direction when + or - is called
By Leadhead in forum Machine DiscussionReplies: 1Last Post: 04-07-2017, 11:48 AM -
Dumb Reverse
By Leadhead in forum General DiscussionReplies: 3Last Post: 03-10-2016, 12:41 PM -
Reverse engineering
By mikewatch in forum Probing, Digitizing & ScaningReplies: 1Last Post: 13-04-2013, 10:20 PM -
Reversing motor direction in Mach3
By bruce_miranda in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 16-11-2008, 06:54 PM
