Thread: Kit's Machine
Thanks Dean. I did wonder if it might have been an installation option I'd forgotten about. It's quite a while since I loaded the demo version and the old brain isn't quite what it was.
Do you know if anyone has written any modified skins for UCCNC? The default layout is a bit of an odd resolution and the manual says it is completely reconfigurable. That might be something to look at AFTER I have it all up and running. You could have a JAZZCNC special edition screen layout!
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
14-04-2021 #2
Working on it Kit, the screen is very easy to edit actually, much easier than mach3 and Linux.
If you check the forum there are several screens available and the development version uses a completely different layout and colour scheme, though I'm not a fan of it.
Don't be afraid to use the development version it's rock-solid stable provided your PC is a decent spec.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
14-04-2021 #3
Duhhhh! If I had a brain I'd have been all over the forum weeks ago.
I've got most of the machine configuration set up now and have started ripping out the old hardware to replace with the new. Fingers crossed it's just a drop-in replacement that works even better than before.
Newbie Machine Build Log (Fancy Machine)
By Fancy in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 18-09-2018, 06:15 PM -
Help please Retain mach 3 licence for my next machine when selling current machine
By suesi34e in forum Artsoft Mach (3 & 4)Replies: 10Last Post: 14-02-2018, 12:45 AM -
4Axis 0.8KW Router Engraving Machine Milling Drilling Engravor 3040 CNC Machine
By KeithElcomb in forum Chinese MachinesReplies: 0Last Post: 27-09-2017, 12:32 PM -
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM
