I hope it doesn't come as too much of a shock but the comments about the amount of work involved in post #3 will apply no matter what control system you change to.As it is you have a machine with a serious,but dated,integral controller and it sort of works.The alternatives involve running a PC front end to achieve the same performance and a mountain of work to get to where you are now in terms of producing parts.
You also need to get a lot more familiar with both CAD and CAM software in order to generate the Gcode.If there is any kind of business imperative requiring parts to go out of the door and bring in an income it may all take quite a while.Unless you get going with whats there and learn more about the upgrade path in the background i.e. evenings and weekends so a quick and effective swap can take place while still producing during the day,it could be s long time before you make any money.
All CAM software has the same requirements,a series of connected elements for outlines holes located where required and a list of tools with which to cut the parts.You may have to set the tools accurately in their collets and model them precisely in a tool library.Then you tell the program which of the tools will be required for each operation,which side of the line it has to go and how deep it has to cut.At which point you post process the information and send it to the machine.I don't know if you have to draw within AlphaCAM or if you are importing from other software,to an extent it doesn't matter,just as long as complete information is present.The difficulty you seem to be having is setting the part datum relative to the home position,otherwise your dated software seems to be working.Have you compared an AlphaCAM upgrade to the cost of the alternative hardware and the extensive learning and development process?
The Following User Says Thank You to routerdriver For This Useful Post:
Rye Quantum First Start... Drive Fault
By BEACHBLANKET in forum Rye CNC RoutersReplies: 53Last Post: 03-08-2020, 05:50 PM -
Advice on setting cutter depth on a omicron 3000
By Sean F in forum Machine DiscussionReplies: 6Last Post: 29-07-2020, 02:45 PM -
Rye cnc twin head quantum midi
By Sean F in forum Rye CNC RoutersReplies: 4Last Post: 21-07-2020, 02:28 PM -
NEW MEMBER: NEWBIE(ISH) with a RYE Quantum QM2515
By BEACHBLANKET in forum New Member IntroductionsReplies: 8Last Post: 18-07-2020, 01:22 AM -
Kompas F-3000 Opinions?
By hockinsk in forum Machine DiscussionReplies: 0Last Post: 02-12-2017, 11:54 PM
