My friend has ordered a pallet-load of kit from SZGH. He has organised someone to make up adaptor plates for the new AC servos, to replace the SEM motors. It's a few hundred quid more than using the SZGH 1000mdb controller with new DC drives and existing motors but it should be simpler to put together - probably not the route I would have taken if it were my own machine but he wants to be up and running with minimum fuss and I don't want another project. I have my own mill to convert one day...
I've been through the SZGH manuals and while they are not exactly perfect English, to date they seem pretty good. You aren't going to learn how to build a CNC machine from scratch with them but if you know what you are doing it seems ok.
We'll have to sort out details like adding home switches, incoming mains switching, stuff like that, but nothing too complicated, I hope.
24-08-2020 #2
Well so far I'm very satisfied with SZGH and the manual isn't that bad after you have read it a few times. It also makes more sense when you have the controller in front of you.
Prep him that while the controller is set up to some degree by SZGH he will still have to play with some settings and he will 99% need to tune the servos to the drives when on the machine. This cannot be done off the machine.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Upgrade questions fro beaver mill VBRP Mk2 with Anilam Crusader II controls
By Breg90 in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 25-05-2020, 08:08 PM -
RFQ: Semi automatic welding system Linear beam control system
By richway in forum Projects, Jobs & RequestsReplies: 0Last Post: 24-01-2017, 08:54 PM -
Fix engrave vertical gap or Upgrading laser cutter control card Leetro MPC6515 ?
By Paul Shroom in forum Machine DiscussionReplies: 3Last Post: 18-05-2014, 03:40 AM -
FOR SALE: £500 Vertical milling machine on stand, ready for steppers and control system
By petemono in forum Items For SaleReplies: 0Last Post: 06-02-2014, 09:52 PM -
drive control system
By oadamo in forum General ElectronicsReplies: 1Last Post: 22-05-2011, 07:30 PM
