22-08-2020 #12
The Anilim Motors I have used 10000ppr encoders with Tacho but single-ended. They connect to the rotor with a 1/4" shaft which screws into the end of the rotor, the encoder then clamps to the shaft fastened with a grub screw, they sit on little slotted spring steel upstands which fasten to the motor plate and allow it to be adjusted.
I've replaced the encoders with differential 2500ppr quadrature encoders but these came with 6mm hole so removed the pin and turned them down on lathe. Simple and easy upgrade.
No I believe you can only wire Limits in series which go to L+ and L-, the home switches go to the X0, Y0, Z0 inputs.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Upgrade questions fro beaver mill VBRP Mk2 with Anilam Crusader II controls
By Breg90 in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 25-05-2020, 08:08 PM -
RFQ: Semi automatic welding system Linear beam control system
By richway in forum Projects, Jobs & RequestsReplies: 0Last Post: 24-01-2017, 08:54 PM -
Fix engrave vertical gap or Upgrading laser cutter control card Leetro MPC6515 ?
By Paul Shroom in forum Machine DiscussionReplies: 3Last Post: 18-05-2014, 03:40 AM -
FOR SALE: £500 Vertical milling machine on stand, ready for steppers and control system
By petemono in forum Items For SaleReplies: 0Last Post: 06-02-2014, 09:52 PM -
drive control system
By oadamo in forum General ElectronicsReplies: 1Last Post: 22-05-2011, 07:30 PM
