When you say "modern encoders", nothing's changed in the meantime. You just need to know if your encoders are single-ended or differential output and which of those your drives require, using a converter if necessary. My SEM motors from the early 80s had Heidenhain encoders with differential outputs that wired directly into the cncdrive DG4S-16035 drives - quick and easy, no messing.
The main difference between DC drives today and 20 odd years ago is that now they use microcontrollers rather than analogue circuits. So you can throw away the tachogenerator and simply use an encoder. Conversely, an actual resolver would be a PITA that you'd want to replace with an encoder. Resolvers give some measure of absolute position, whereas encoders only tell you how many clicks the motor has moved. Again, my SEM motors had tachos but I simply left them in place, as removing them would have involved additional ballache for no obvious benefit.
Upgrade questions fro beaver mill VBRP Mk2 with Anilam Crusader II controls
By Breg90 in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 25-05-2020, 08:08 PM -
RFQ: Semi automatic welding system Linear beam control system
By richway in forum Projects, Jobs & RequestsReplies: 0Last Post: 24-01-2017, 08:54 PM -
Fix engrave vertical gap or Upgrading laser cutter control card Leetro MPC6515 ?
By Paul Shroom in forum Machine DiscussionReplies: 3Last Post: 18-05-2014, 03:40 AM -
FOR SALE: £500 Vertical milling machine on stand, ready for steppers and control system
By petemono in forum Items For SaleReplies: 0Last Post: 06-02-2014, 09:52 PM -
drive control system
By oadamo in forum General ElectronicsReplies: 1Last Post: 22-05-2011, 07:30 PM
