    Hi all,
    I am a new member of this forum and really hoping someone can help / offer advice . I make craft mirrors from slate , mainly basic rectangular designs which I cut out using an Angle grinder and diamond disc , I would like to do some more detailed work as per the examples attached , however I have no idea of machinery / equipment I would need to get this type of detail , if anyone could offer any advice it would be greatly appreciated .
    Best Regards
    Andy
    Waterjet
    Thanks, I have done a quick google search of waterjet cutting and I can see why you are suggesting that as it does look like it would achieve this kind of fine detail , however the equipment looks very expensive and it would be very difficult to afford for low volume craft type work , do you think there would be any other way of doing this with more conventional cutting tools / equipment ?
    Best Regards
    Andy
    There have been some DIY waterjet cutters built using a pressure washer as the pump. I have no idea whether the level of detail you're after is possible but it might be worth a few minutes on Google just in case.
    This the first result of a search for 'DIY waterjet'...
    https://www.youtube.com/watch?time_c...ature=emb_logo
    Worth looking at something less esoteric (though I've spent an hour of my life watching the electric/petrol water cutters before realising the cutting costs!)...
    https://www.youtube.com/watch?v=FHyj_nbfILM
    Last few seconds does show routing rather than just engraving.
    Only water jet or high power laser can achieve that level of detail with such sharp corners etc. Routing will give radius in the corners even with small cutters and won't get close to that sharp of detail.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    If you're thinking of going the high power laser route, it might be worth doing a test cutting with the particular type of slate you're intending to use. We have a number of quarries round here and some types seem to be tough as old boots, others start to delaminate when heated.
    You can buy thin wire, diamond coated scroll saw blades for cutting stone. How about a CNC controlled bed for a scroll saw? Obviously the size you could cut would be limited unless you plan to build the scroll saw from hell.
    Where did your example picture come from? Any clues from that source?
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,971. Received thanks 369 times, giving thanks to others 9 times.
    I was thinking along the same lines, but with diamond wire.
    There was a guy created a big CNC stone cutter over on the Dynomotion forum (might actually of been the Dynomotion board on cnczone)
    I mostly remember the KFlop servo tuning, as he had to resort to writing a C program to export the tuning data, as the servos moved too slow for the normal tuning functions to be any use. IIRC the servo plots had to be done over a few minutes, as the typical few seconds gave nothing meaningful for tuning.
  10. The Following User Says Thank You to m_c For This Useful Post:
  11. #10
    One could build quite the pyramide using this CNC saw
  1. Black Slate Engraving
    By Leadhead in forum General Discussion
    Last Post: 12-03-2020, 09:01 PM
  2. Fine detail Wood.
    By Leadhead in forum Wood Finishing Tips & Tricks
    Last Post: 18-02-2017, 04:36 PM
  3. No detail imported stl file
    By luke11cnc in forum Rhino 3D
    Last Post: 30-01-2015, 10:19 PM
  4. Router bits for use with Slate
    By habibuzziwa in forum Tool & Tooling Technology
    Last Post: 30-06-2013, 06:12 PM
  5. Laser engraving slate
    By Philly in forum Laser Machines & Building
    Last Post: 18-11-2012, 08:19 PM
