I see your point, but I think you also have to consider what's best in terms of cooling. In something like a medium>high power VFD likely 90+% of the heat will likely be generated by power devices on the heatsink, therefore primary concern need to be generating a fast turbulent airflow passing over that, easiest way is fan at the bottom end with a baffle/wall over the top of the fins to stop the air taking a short cut. Yes, you could do this with distributed inlets and sucking, but it would then involve a certain amount of baffles/ducts to direct the flow to where it's needed, which would likely make the unit bigger.
The point about crap getting into the unit is a good point though, and makes @marbles 3KW unit sound even stranger, as taking in air from the bottom has to be the best place to avoid that. I put my VFD in the cabinet when I built it and even added mesh screens on the cabinet ventilation to keep chips/swarf out, and am heartily glad I did as the surrounding floor looks like it's been snowing aluminium at the end of a machining session.
Quick question regarding spindle direction
By ravihotwok in forum Spindles & Drive MotorsReplies: 4Last Post: 23-10-2019, 12:12 PM -
Huanyang HY02D223B VFD Question
By iforeman in forum General DiscussionReplies: 2Last Post: 26-10-2017, 05:00 PM -
Stepper direction problem, only one direction when + or - is called
By Leadhead in forum Machine DiscussionReplies: 1Last Post: 04-07-2017, 11:48 AM -
Axis direction help please?
By examorph in forum General DiscussionReplies: 2Last Post: 24-01-2017, 06:30 PM -
Am I heading in the right direction?....
By Lloyd in forum Gantry/Router Machines & BuildingReplies: 24Last Post: 24-06-2014, 09:09 PM
