    Yep thats right. I have just found that the motors are not locking with mach 3 on if that gives any clues
    Quote Originally Posted by johngoodrich View Post
    That suggests the drives are not turning on. do you have the enable signal connected on the drives.? If yes then remove these and see if they lock up. If they do then you have the wrong wrong pins set for the enable outputs or the active Hi/Lo is wrong.
    Other than controlling the enable outputs if used then Mach3 as nothing to do with the drives turning on.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
