Thread: someone please help
15-08-2020 #4
That suggests the drives are not turning on. do you have the enable signal connected on the drives.? If yes then remove these and see if they lock up. If they do then you have the wrong wrong pins set for the enable outputs or the active Hi/Lo is wrong.
Other than controlling the enable outputs if used then Mach3 as nothing to do with the drives turning on.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
