Problem sorted out :) Parameters P1-68 and P1-77 Position command moving filters was set to 100. I've changed them to zero and all works fine now. Very happy :)
22-08-2020 #2
Unfortunately with servo's you are in a world where parameters and motor tuning are something you have to deal with to get the accuracy, esp if moving at high velocity like what you are doing. After a while, you'll get used to adjusting them and finding how one affects the other, just keep a log on what you change with the effect it has and only make one change at a time then test.
I suspect you'll find some more tuning will be required before your fully happy and it's 100% accurate.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
23-08-2020 #3
Thank you JAZZCNC. You are right. I’m keeping a log and saving every change in new backup file in the tuning software.
I just uploaded a video after the fix https://youtu.be/m_4eACqxWOk . Of course I’m not a 100% happy but now machine doing what it have to do. Fine tuning I believe will be much easier when machine works and executing the proper size and shape of the objects.
Thanks again. Have a great Sunday
Huanyang 2.2kw spindle with Delta 2.2kw VFD (programming)
By Kuyguk in forum General DiscussionReplies: 1Last Post: 14-08-2020, 09:06 AM -
Servio motor Delta adas b2 Software and electronic gear ratio
By jhonansaro in forum General DiscussionReplies: 3Last Post: 16-03-2018, 08:09 PM -
Some body know abaut Delta asda a2 servo and drive
By carlosdvb in forum Stepper & Servo MotorsReplies: 6Last Post: 30-04-2016, 06:06 PM -
Building a delta
By Jester in forum 3D Printing MachinesReplies: 3Last Post: 16-09-2015, 10:18 AM -
FOR SALE: Delta pump
By onecut in forum Items For SaleReplies: 0Last Post: 15-05-2014, 02:59 PM
