    Quote Originally Posted by Maxiscnc View Post
    Problem sorted out :) Parameters P1-68 and P1-77 Position command moving filters was set to 100. A've changed them to zero and all works fine now. Very happy :)
    Unfortunately with servo's you are in a world where parameters and motor tuning are something you have to deal with to get the accuracy, esp if moving at high velocity like what you are doing. After a while, you'll get used to adjusting them and finding how one affects the other, just keep a log on what you change with the effect it has and only make one change at a time then test.
    I suspect you'll find some more tuning will be required before your fully happy and it's 100% accurate.!
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Thank you JAZZCNC. You are right. I’m keeping a log and saving every change in new backup file in the tuning software.
    I just uploaded a video after the fix https://youtu.be/m_4eACqxWOk . Of course I’m not a 100% happy but now machine doing what it have to do. Fine tuning I believe will be much easier when machine works and executing the proper size and shape of the objects.
    Thanks again. Have a great Sunday
  1. Huanyang 2.2kw spindle with Delta 2.2kw VFD (programming)
    By Kuyguk in forum General Discussion
    Last Post: 14-08-2020, 09:06 AM
  2. Servio motor Delta adas b2 Software and electronic gear ratio
    By jhonansaro in forum General Discussion
    Last Post: 16-03-2018, 08:09 PM
  3. Some body know abaut Delta asda a2 servo and drive
    By carlosdvb in forum Stepper & Servo Motors
    Last Post: 30-04-2016, 06:06 PM
  4. Building a delta
    By Jester in forum 3D Printing Machines
    Last Post: 16-09-2015, 10:18 AM
  5. FOR SALE: Delta pump
    By onecut in forum Items For Sale
    Last Post: 15-05-2014, 02:59 PM
