Thread: Maybe my Mk 2 table conversion
So I completed my table conversion
http://www.mycncuk.com/threads/13746...ld-Deckel-mill
And indeed it runs reasonably (well in my opinion anyway)
https://www.youtube.com/watch?v=Fvzp8hJjGyY&t=6s
I would welcome any comments particularly regarding potential improvement . ( I know I need to protect the limit switches cos they easily get bridged with chippings) guards were off for a reason when I took this .
It has been a great learning experience, and thanks to the help of a few folks here (you know who you are ) I can achieve rudimentary cambam drawings, and run simple milling routines , and I have found it very satisfying and indeed have learned a lot
So this table was initially a £40 lump of scrap iron and has its limitations as a result ( silk purses and sows ears spring to mind) but I like the principal of planting this kind of table on my old miller , It gives me quite a versatile solution for my limited space.
I am now hoping to move on and build an improved version based upon this table
https://www.ebay.co.uk/itm/COMPOUND-...53.m1438.l2649
So I need to learn a bit more and hope that you folks will keep me on the straight and narrow
For Starters :-
How do I calculate the correct sizes for the stepper motors to handle larger cutting forces as well as the greater inertia of the table.
Which motors and drivers should I choose ? Shoud I go to so called "servo" types
https://www.ebay.co.uk/itm/HSS86-Hyb....c100677.m4598
With regard to ball screws will 1605 be adequate
And generally with regard to quality of gear , should I be going to a British supplier , or will he just sell me (at an elevated price) the same gear as I could buy myself from china anyway
That should get me going . If you are able to give me the benefit of your opinion.
Thanks in Anticipation
PS I am only looking at the x / y functions at this stage . the spindle function will be needing a bit more thought so initially I will keep what I have got
CONVERSION: Compound table conversion of an old Deckel mill
By John11668 in forum Conversion Build LogsReplies: 6Last Post: 29-06-2020, 12:21 PM -
CONVERSION: Conversion of an old milling machine using a CNC compound table
By John11668 in forum Conversion Build LogsReplies: 2Last Post: 01-06-2020, 10:50 AM -
eBay: NEAT XY-1010 xy table 8" travel very solid 17kg table NEW ebay.co.uk 251715555999
By emlclcy in forum Items On eBay UKReplies: 0Last Post: 12-11-2014, 09:14 AM -
MY 4`x 4` table
By Steve-m in forum DIY Plasma Build LogsReplies: 65Last Post: 30-10-2012, 12:07 AM -
Clamp table
By Lee Roberts in forum Programmers CornerReplies: 2Last Post: 14-10-2008, 03:03 AM
