30-08-2020 #23
Fuse?, a transient voltage suppressor (TVS) is not intended to protect in the manner that he orchestrated.
The servo inputs, apart from the step/dir, are intended to be driven by the 12/24V supply to the servo driver, and through current sink inputs. The step/dir are intended for 5V differential, or single-ended supplies.
If you want to understand the difference - look at the resistors attached internal to the servo controller on page 11-13 of the manual - the step/dir are 270R (from memory), and the other inputs are 4.7k (4700R). Each opto-isolator device has an internal LED (the term opto-isolator is a bit confusing - they provide electrical isolation, by using an infra-red light between a LED and a photo-transistor across an air-gap, so the mechanism to drive this is to drive the LED 'on'). The LED will have, from memory, around 1.8V forward voltage drop. For the step/dir, 5v-1.8V = 3.2V. Through a 270R resistor, that's around 12mA (Ohm's Law: I=V/R). Typically drive current for a LED like this is around 10mA (max 20mA), the optical power is broadly proportional to the current - the choice of 270R is a standard value in the E3 etc range of resistor values - it's a "rule-of-thumb" resistor value). Now, the other inputs, with 4700R resistors - again, drop 1.8V across the LED, and if you're driving the stepper controller with 12V, then 12-1.8 = 10.2V, I = 10.2/4700 = 2mA, or at 24V then 24-1.8 = 22.2V, I = 22.2/4700 = 5mA. Actually, the currents a little low, but obviously it works - but hopefully you can see that if the 5V works on the Step/Dir at 12mA, that the other inputs with 4k7 resistors are perfectly safe at 24V because of the choice of resistors selected by the designer. being honest, I think the designer has been a little cautious.
Again, it's information provided by the manual that takes a bit of background knowledge/understanding to interpret properly.
But, yes, unduly worrying - the Step/Dir are designed for 5V signalling, the other controller inputs designated for current-sinking through a 4k7 resistor are designed for 12-24V signalling.Last edited by Doddy; 30-08-2020 at 05:13 PM.
The Following User Says Thank You to Doddy For This Useful Post:
MSD043A1XXV Panasonic AC Servo Driver 400w - MB3 connection help
By Nemo1966 in forum General DiscussionReplies: 2Last Post: 27-08-2020, 07:54 PM -
Cheap servo drives & motors 200w- 400w , sourcing ? Europe?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 9Last Post: 29-05-2015, 04:10 PM -
400W servo - Leadshine ACS806 + ACM604V60 driver - PSU size?
By dsc in forum Stepper & Servo MotorsReplies: 10Last Post: 23-04-2013, 05:33 PM -
Panasonic 3 phase driver running on 1 phase?
By gavztheouch in forum Motor Drivers & ControllersReplies: 2Last Post: 10-05-2012, 11:21 PM -
FOR SALE: 400w panasonic ac brushless servo motors and drives
By gavztheouch in forum Items For SaleReplies: 3Last Post: 29-12-2011, 03:04 PM
