    I am looking for a UK stockist of a Sanyo Denki 103H7124-0440 UK and am not having much luck.
    Can anyone point me to a supplier or suggest a suitable replacement available in the UK?
    Full specs for the stepper are available here
    https://search.sanyodenki.comhttps:/...OTION_F2_E.pdf
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 5 Hours Ago Has been a member for 8-9 years. Has a total post count of 491. Received thanks 82 times, giving thanks to others 27 times.
    That link is scrambled. Try this https://www.sanyodenki.com/archive/d...OTION_F2_E.pdf
    Page 52. 56 mm sq. 1.8°/step Unipolar winding, Lead wire type, ~1Nm, 2A, 3.1mH
    Muzzer's Avatar
    There's a slightly lower torque version of it on Irish ebay ATM - 0.83Nm instead of 0.98Nm. https://www.ebay.co.uk/itm/SANYO-DEN...AAAOSwYgRZlwF2
    Can't you find an equivalent motor from an alternative supplier? These come in reasonably std frame sizes.
    Quote Originally Posted by Muzzer View Post
    Thanks. I would rather go up in torque an new to all this hence making sure I get it right.
    My drivers are Stepper Motor Driver 6.0A, 80V CNC Microstepping CW8060 from cnc4you. I have enough space so am I correct that this unit will do? M57STH76-2808S as listed on https://www.motioncontrolproducts.co...tepper-motors/
    Muzzer's Avatar
    It looks about right to me but I'm not the expert on steppers. Certainly, the inductance and dimensions look compatible from what I can make out.
    Perhaps somebody else could give an opinion?
  1. Bulb replacement
    By calida in forum Laser Machines & Building
    Last Post: 19-01-2016, 11:03 PM
  2. Replies: 0
    Last Post: 27-06-2014, 10:24 PM
  3. Replies: 0
    Last Post: 22-06-2014, 01:59 PM
  4. Sanyo Denki stepper motors
    By djk in forum Stepper & Servo Motors
    Last Post: 26-04-2013, 09:27 PM
  5. NEW MEMBER: Sanyo Seiki
    By SanyoSeiki in forum New Member Introductions
    Last Post: 08-02-2012, 08:33 AM
