Quote Originally Posted by John11668 View Post
Linux does sound a bit intimidating when and maybe a further complication. I think I would like to get this machine up and running before going to another level.
I have been thinking out of the box
My mill table has plugs on the drive board for each axis cable .
If I were to make two leads to plug into x and z sockets and connect to x and z motors on the lathe then I should at least be able to test the axis motors .
I do have Mach 3 on the computer so should be able to call up a Lathe profile and set it up.
I might not even need to buy any gear at all. A good Yorkshire solution maybe , but must be careful not to upset the Lancashire men
It should work for testing
Long term it would not be a great solution
Are the stepper voltages similar?
Re linuxcnc for a basic setup the step and configure wizard will work perfectly
Download the package and burn it to a DVD then pop it in a laptop or desktop and let it boot from the cd. You will be able to run a ‘test’ version to get a feel for it before you install it to a hard drive
I can talk you through the very basics of linuxcnc if it helps
Paul
