Thread: Boxford TCL 125
Page 4 of 9 FirstFirst ... 23456 ... LastLast
  1. #31
    inee's Avatar
    Lives in bris, United Kingdom. Last Activity: 19-09-2022 Has been a member for 5-6 years. Has a total post count of 21. Received thanks 1 times, giving thanks to others 0 times.
    Quote Originally Posted by depronman View Post
    I am using linuxcnc on an Orac lathe. Using two parallel ports one on motherboard and a pci card running an encoder limit switches and a number of control panel buttons. Cycle start stop pause etc. It’s been rock solid since I set it up after the conversion some 8 months ago
    I’ve used mach3 but linuxcnc is just sooooo much better
    Gmaccopy is a major improvement over axis as a screen interface. All I can say is it just works where as Mach3 would and still does on my other cnc lathe have its moments
    I would go to linuxcnc on that one as well but I invested in a pokeys motion controller and don’t want to bin that so mach3 will love on for the time being
    Paul
    Quick question
    When i looked into linuxcnc, it said once installed do not update the linux distro.
    Is that still the same today or have they found a way to allow update of the linux, was thinking about caelinux as its geared towards cad etc, can linux cnc be added to cae at all
  2. #32
    I have updated linuxcnc to the latest development version without issue
    Paul
  3. #33
    May look at linux , but that will be down the linea bit for me . Will probably start with Mach 3
    Need to establish what is preventing these traverses from traversing.
    Off now to try and trace these interlock wires , Now where did I leave those sidecutters?
  4. #34
    Have traced the interlock wiring and tested . All seems fine
    Tries the rotary feed controller in all position - no difference
    Am I right in thinking that if interlocks were not in there proper positions then spindle would not be expected to start (which it does , forward and reverse and speed variation on both) so relay and lenze controller seem sound .
    Will go and inspect the upper board with the stepper drivers .
  5. #35
    Pics of boards
    Some dubius looking repairs on the upper one ???
    Any thoughts anyone
ID:	28822   Click image for larger version.
  6. #36
    Hi folks .
    I have found and downloaded a manual for TCL 160 which includes both mechanical and electrical info and would appear to be virtually identical in the main to 125 and seems to be pretty comprehensive WRT elementary faultfinding.
    I will go and have a read.
  7. #37
    Quote Originally Posted by John11668 View Post
    Hi folks .
    Would you mind putting a link to it if you can.
  8. #38
    I will send you a pm Clive.
    Site is here , https://www.machinemanuals.co.uk/manual.php?p=204 . Their £12 is a bit better than lathes.co.uk at £65
    Looks pretty comprehensive and I wonder if they may be infringing copyright by selling it anyway.
    Not sure about the legallity of buying a copy then posting on a forum ??????
    Not averse to doing so as long as I know they cant touch you for it.
  9. The Following User Says Thank You to John11668 For This Useful Post:
  10. #39
    inee's Avatar
    Here's the dimensions of the Z Axis actuator rod.
    Forgive the look of it as I'm not good with paint programs. the rod is a 10MM dia bar. The 2 missing dimensions on one pic take from another as for some reason my paint program decided not to allow me to put text on anymore
  11. #40
    Thanks for that Inee and to all that have helped me with this thank you too .
    Manual doesnt help a lot , but I feel that interlocks and and spindle controls seem OK
    Voltages at transformer seem good and seem OK at the board connectors, and all LEDs light up , but I wonder if I can follow supplies across the board.
    Any suggestions on best way??
  1. FOR SALE: Boxford MT2 & Boxford TCL125
    By jonnydeen in forum Items For Sale
    Last Post: 12-11-2021, 11:24 AM
  2. Boxford CAD/CAM V10
    By maaz013 in forum Boxford Vertical Mills
    Last Post: 22-08-2019, 12:42 PM
  3. SOLD: Boxford 260 VMC
    By Woodfish in forum Items For Sale
    Last Post: 11-12-2018, 08:34 PM
  4. Replies: 2
    Last Post: 21-04-2016, 09:18 AM
  5. Boxford 165 HMC
    By uli12us in forum Boxford Vertical Mills
    Last Post: 24-01-2016, 08:21 PM
