Thread: Boxford TCL 125
08-09-2020 #11
Our vintage bike got converted to 12v in order that it could handle a modern starter motor ,which for a 350cc single is quite an advantage . But we did have to replace the old plate rectifier with a modern solid state bit of kit ,
But we digress!
Linking those terminals Inee had no effect but the 24 v supply was not there . There was however 20v at the input of the missing fuse and it looked like the output from the rectifier headed in the correct general direction, so took a risk, replaced the fuse , and switched on
A 24 v led lit up on the board and lo the spindle functions all seem to work as we would expect.
I will post the requested pics you ask for Inee but too late tonight .
Traverses do not work yet, regardless of the position of the Manual switch but someone did say it would be surprising if traverses worked without a computer connected so maybe that should be next step,
I did manage to get hold of the "Boxford engineer " who owns up to not having proven the functions before the machine was sold . It seems he was a factory mechanical fitter and whilst they were trained to carry out limited electronic testing, he relies on an electronic specialist as he needs one.
He does however have a number of spares so might be worth knowing .
One thing he mentioned was that he thought there were traverse limits , to prevent crashes , and it could be that these might be operated .
I will check that tomorrow .
With a serial connector on the machine, I presume there must be some breakout function within the boards. Might it be time to connect a computer and see what gives.
Will it matter whether we are running Mach 3 or UCCNC? I guess we will need to know pin identities, etc but I will not go there until I have the benefit of your invaluable opinions
Looking forward to those .
FOR SALE: Boxford MT2 & Boxford TCL125
By jonnydeen in forum Items For SaleReplies: 3Last Post: 12-11-2021, 11:24 AM -
Boxford CAD/CAM V10
By maaz013 in forum Boxford Vertical MillsReplies: 1Last Post: 22-08-2019, 12:42 PM -
SOLD: Boxford 260 VMC
By Woodfish in forum Items For SaleReplies: 6Last Post: 11-12-2018, 08:34 PM -
FOR SALE: Boxford 160tcl Lathe and 260 vmc milling machine with full boxford software for sale
By Waine in forum Items For SaleReplies: 2Last Post: 21-04-2016, 09:18 AM -
Boxford 165 HMC
By uli12us in forum Boxford Vertical MillsReplies: 48Last Post: 24-01-2016, 08:21 PM
