Thread: Boxford TCL 125
    If you have the drives already then it's a no brainer to use for both. Clive S did this for years and run a Mill and Lathe from same Control box using a change over switch. Obviously you can't run both together but how likely are you to ever do that.?
    Like Depronman says for a basic setup the Linux CNC Config Wizzard is easy enough to use and it costs nothing to try. You already have a working machine and know all the I/O pins so just try a Config with the settings for your Router and plug into a parallel port. Lathe is pretty much the same just less axis.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Will give it a try if only to prove the steppers.
    Then maybe play a while maybe before I try linux. I suspect I will need some hand-holding if /when I get to that stage .
    The computer I am using here cost me £50 3 years ago , and if initially I am not paying for drivers another one at £40 from Ebay isn't gonna break the budget.
    https://www.ebay.co.uk/itm/Dell-Opti....c100005.m1851
    And part of the cost will be getting paid by the guy who told me this was a working machine , only he doesnt know it yet.
    What sort of a machine spec will I need to run linux and Am I better with 32bit or 64
    And PS Anyone fancy a pair of Boxford boards to fix ?????
    Lives in Marple Stockport, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    64bit as that is the most popular with linuxcnc.
    See my post re the linuxcnc ISO.
  1. FOR SALE: Boxford MT2 & Boxford TCL125
    By jonnydeen in forum Items For Sale
    Last Post: 12-11-2021, 11:24 AM
  2. Boxford CAD/CAM V10
    By maaz013 in forum Boxford Vertical Mills
    Last Post: 22-08-2019, 12:42 PM
  3. SOLD: Boxford 260 VMC
    By Woodfish in forum Items For Sale
    Last Post: 11-12-2018, 08:34 PM
  4. Replies: 2
    Last Post: 21-04-2016, 09:18 AM
  5. Boxford 165 HMC
    By uli12us in forum Boxford Vertical Mills
    Last Post: 24-01-2016, 08:21 PM
