Thread: Help! DIY 4 amp L297/6203 driver
09-11-2009 #2
Hi
I'm not sure about the PIC - R23 is adjusting Vref (driven by Q2/IC5A) into it's GP4 input (which for the '675 is analogue input 3).
But it also does take the CLOCK signal that goes into IC3 (L297).
I don't think it's doing anything to Vref, so it must have the capability of driving CLOCK instead. Otherwise, there's not a lot the PIC could do - all the other IO pins are grounded. Do you have the code for the PIC? That would give more of a clue as to what it's doing.
Any particular reason why in yours you aren't using optoisolators?
D11 on yours should be a triac instead (T1 on the original, middle-bottom).
C15 on yours is the reverse polarity (+ve is going to GND) - next to T1 on the original (C27).
I see you've omitted the power supply circuit (top-right) - are you going to power it from the CNTL port (JP3)? I can't see any other method of providing +5V...
Apart from that, it looks good - but I'll have another look later on.
Edited to add: I suppose the PIC could do things with Vref - although the only things it could do are:
- Power GP4 high
- Power GP4 low
- Pulse GP4
- Leave GP4 open
It might power down the stepper controller if the clock hasn't been used for a while. GP2 is also the INT(errupt) input on the PIC. In which case, I suppose a resettable monostable could do the same job.
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Dc servo driver
By Treemonkey in forum Motor Drivers & ControllersReplies: 11Last Post: 11-02-2013, 08:16 PM -
Driver suggestions
By Shinobiwan in forum Motor Drivers & ControllersReplies: 0Last Post: 04-03-2012, 03:54 PM -
Driver wiring help...
By mike in forum Motor Drivers & ControllersReplies: 12Last Post: 21-09-2010, 09:29 AM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
