Thread: Help! DIY 4 amp L297/6203 driver
12-11-2009 #11
Depends on the chip and whether an O/C output is available. If not, a single NPN small signal transistor and base resistor on the output would suffice.
Having said that, if you are using a transistor, why not put a trimmer on the output side and not use PWM at all... would simplify the code and you could adjust the holding current to your hearts content.
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Dc servo driver
By Treemonkey in forum Motor Drivers & ControllersReplies: 11Last Post: 11-02-2013, 08:16 PM -
Driver suggestions
By Shinobiwan in forum Motor Drivers & ControllersReplies: 0Last Post: 04-03-2012, 03:54 PM -
Driver wiring help...
By mike in forum Motor Drivers & ControllersReplies: 12Last Post: 21-09-2010, 09:29 AM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
