Thread: Help! DIY 4 amp L297/6203 driver
19-11-2009 #16
Ok I'll see what the smallest 100v caps are. The only bit I'm stuck with is the high power resistors. The Original dosnt show a rating and the similar Burger design shows the bootstraps as 2 watt and the sense res as 5 watt! dose this seem right?
The other problem is that although the original board used this configuration the motors are only 2 amp per phase so I will need to lower these values to set a temporary 2 amp max current. This shouldnt affect the pcb layout tho. maybe just use a large res mounted vertically?
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Dc servo driver
By Treemonkey in forum Motor Drivers & ControllersReplies: 11Last Post: 11-02-2013, 08:16 PM -
Driver suggestions
By Shinobiwan in forum Motor Drivers & ControllersReplies: 0Last Post: 04-03-2012, 03:54 PM -
Driver wiring help...
By mike in forum Motor Drivers & ControllersReplies: 12Last Post: 21-09-2010, 09:29 AM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
