Thread: Help! DIY 4 amp L297/6203 driver
	17-11-2009 #10
The PIC doesn't really need a clock (it depends on which one you use).
Since I've got them, you may as well use 12F683 - it doesn't need an external crystal or clock (it's got an 8MHz clock built-in). It's 8-pin: 2 power, 1 input and 5 I/O.
If you're referring to replacing the 7415, then I would keep it as it is - you'd need to monitor the lines, and there would be a delay. But then, if you're not clocking the circuit very fast, then it would probably be okay. But, as you mention, it does save on code complexity
For the PIC, you can use any of the output pins (pins 2, 3, 5, 6 and 7) for the VREF generation signals, but use one of the analogue pins (5, 6 and 7) with a trimmer (between VCC and GND) to set the delay.
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Dc servo driver
By Treemonkey in forum Motor Drivers & ControllersReplies: 11Last Post: 11-02-2013, 08:16 PM -
Driver suggestions
By Shinobiwan in forum Motor Drivers & ControllersReplies: 0Last Post: 04-03-2012, 03:54 PM -
Driver wiring help...
By mike in forum Motor Drivers & ControllersReplies: 12Last Post: 21-09-2010, 09:29 AM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
