Thread: Help! DIY 4 amp L297/6203 driver
17-11-2009 #10
Just to clear any confusion - you the 3k9 res should be removed from the +5v line and connected to a port. The voltage at the other end will never exceed 1v.
Another resistor is connected the same (19k??) one end to the junction of the VR and the 3K9 the other to a second port.
Basically the PIC will pull either of the lines high - if it pulls the 3k9 one high you get whatever current you've set the VR for, if it pulls the 19k one high you get a quarter of that.
The pic avoids interference by essentially disconnecting the unused resistor (tri-stating the output).
I've also realised in my pseudo code there's no need to set the port pins high in the loop - this can be done outside - plus I don't show the pin being 'un-tri-stated' - which obviously it would need.
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Dc servo driver
By Treemonkey in forum Motor Drivers & ControllersReplies: 11Last Post: 11-02-2013, 08:16 PM -
Driver suggestions
By Shinobiwan in forum Motor Drivers & ControllersReplies: 0Last Post: 04-03-2012, 03:54 PM -
Driver wiring help...
By mike in forum Motor Drivers & ControllersReplies: 12Last Post: 21-09-2010, 09:29 AM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
