Thread: Help! DIY 4 amp L297/6203 driver
18-11-2009 #14Hurray at last :heehee:Yes (from my side
I thought we'd ruled out an all in one board? also wouldnt this also mean the control is global? I was hoping to be able to set up each motor separatly.If you were to put all 3 on the same board, you could use a single PIC to control them all - then there'd only be one pair of trimmers for the duration/hold...
So just need to check the type and size of a few components and we should be good to go.
Are there any parts to look out for? I now the polar caps just have to be 50v and the sense resistors 2 watt. Can the caps be any type or is polyester or tantilum required?
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Dc servo driver
By Treemonkey in forum Motor Drivers & ControllersReplies: 11Last Post: 11-02-2013, 08:16 PM -
Driver suggestions
By Shinobiwan in forum Motor Drivers & ControllersReplies: 0Last Post: 04-03-2012, 03:54 PM -
Driver wiring help...
By mike in forum Motor Drivers & ControllersReplies: 12Last Post: 21-09-2010, 09:29 AM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
