Thread: Help! DIY 4 amp L297/6203 driver
19-11-2009 #17
Vref = 0.5v, phase current = 4A therefore sense resistor is 0.5/4 = 0.125ohm and dissipates 0.5 * 4 W = 2W so need to be 5W rated.
Why would you need to reduce them for 2A, just turn down Vref to 0.25V. I would recommend a 10 turn pot for the Vref trimmer, makes it so much easier to set.
What have you planned for heatsinking the 6203s?
From the datasheet, at 4A you are going to dissipate between 10 and 15W. Max junction temp is 150, max case temp 90 so for an ambient of 25degC you'll need better than (90-25)/15 = 4degC/W heatsink per 6203 - I'd go for ~3degC/W. thats going to need a finned heatsink around 60mm x 100mm each chip...
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Dc servo driver
By Treemonkey in forum Motor Drivers & ControllersReplies: 11Last Post: 11-02-2013, 08:16 PM -
Driver suggestions
By Shinobiwan in forum Motor Drivers & ControllersReplies: 0Last Post: 04-03-2012, 03:54 PM -
Driver wiring help...
By mike in forum Motor Drivers & ControllersReplies: 12Last Post: 21-09-2010, 09:29 AM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
