Thread: Cncst4060
Hooraaaaaay this poxy chinky spindle has finally started up and spinning and the problem was in the wiring now its running in reverse but that just needs a wire swapping over i am sure ?????? .
The wiring from the standard black box that came with the machine was all marked from 1 to 4 and no colored wire So for anyone who has bought one of these i sugest you just unscrew the wiring jack on the top of the motor and check fromk the colors if that makes sense and not rely on numerics that someone has written on them .
But now to swap the wires to get it running the right way .......any ideas please
What is the best speed to run this spindle atLast edited by petesos; 15-09-2020 at 10:15 PM.
15-09-2020 #2
Swap any two of the UVW leads to reverse the spindle.
Thanks for reporting back - it's useful for anyone with similar problems.
Speed?, that's the next learning curve for you - depends on cutter size, flutes, material you're cutting, feed rate etc.
They are notorious for being poor performers under 8k rpm.
One last thing was bugging me - is this a water cooled spindle or air cooled?
EDIT: Changed YUV to UVW - apologies - my job involves video systems and YUV was a Freudian slip of the tongue.Last edited by Doddy; 16-09-2020 at 07:44 AM.
The Following User Says Thank You to Doddy For This Useful Post:
16-09-2020 #3
16-09-2020 #4
