Page 1 of 3 123 LastLast
    Hello !
    I am in the design phase of my new CNC machine. I am aming to 120x60 cm working area, And most of my milling will be in Aluminum, Brass, And some steel!
    The frame will be epoxy granite and a welded laser cut steel skeleton inside.
    I prototyped 2 design to choose from, Here's my 2 prototypes
    I really like the U base design (#1) its easy to enclose & Chip control is great.
    But, Is the design #2 stiffer?
    Which one should I go to ?
    Thank you all in advance (:
    I can't help but think that you would get better results with both designs if you rotate your working area by 90 degrees to minimise the gantry length.
    Thank you for your addition. I'll think about this.
    Why put a steel skeleton inside?
    If the steel is for stiffness it is better to put it outside. Material at or close to the neutral axis does very little for stiffness.
    Save the money you would spend on laser cut steel and put it into more epoxy granite for bigger sections.
    Quote Originally Posted by pippin88 View Post
    Are your sure about that ?
    Sure I'll put steel outside for screwing and rails, ballscrews .. etc.
    Epoxy granite alone is that stiff for a large machine ?
    How do you arrive at that thinking? most things have the skeleton inside for strength of the main structure and appearance there would be very little point of having steel outside of Epoxy granite other than to cut down on resonance of a steel box frame you could fill the box with epoxy.
    Phill
    Edit: I would be tempted to go for No2 image
  7. The Following User Says Thank You to phill05 For This Useful Post:
  8. #7
    Thank you for your replay.
    Yes, design #2 have many Advantages, Easier to align, Easier to machine flat, uses 3 motor not 4.
    But will it add any more stiffness more than the #1 design ?
  9. #8
    I believe it will, a fixed gantry has got to be more stable than a moving mass gantry, the only thing is you need more room for the moving table.
    I have a fixed gantry and no problem at all.
    Phill
  10. The Following User Says Thank You to phill05 For This Useful Post:
  11. #9
    Hi EZELab
    Welcome to the forum.
    I would like to point you to John McNamara's epoxy build( https://www.model-engineer.co.uk/for....asp?th=139042)
    A very thorough and informative thread.
    Kindest Regards
    Mike
    Sorry Guys didn't see the last couple of posts, was trying to find the link
  12. The Following 2 Users Say Thank You to mekanik For This Useful Post:
  13. #10
    Removed.
  1. BUILD LOG: Epoxy granite vertical mill build log
    By Nick in forum DIY Mill Build Logs
    Last Post: 08-06-2020, 06:30 AM
  2. Large Format Epoxy Granite Gantry CNC - Looking For Feedback
    By Max Maker in forum Gantry/Router Machines & Building
    Last Post: 23-08-2019, 04:57 PM
  3. BUILD LOG: DIY Epoxy composite gantry frame milling machine
    By John McNamara in forum DIY Mill Build Logs
    Last Post: 03-08-2019, 04:22 PM
  4. Epoxy granite or mineral casting
    By mike mcdermid in forum Gantry/Router Machines & Building
    Last Post: 20-02-2014, 06:21 PM
  5. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 07:28 PM
