Thread: Introduction and design help.
A welded steel frame is fine if you are careful with the weld sequencing, but I would expect it to need some form of levelling still. You can shim the rails level if you have a good straight edge and engineers level, or you could try epoxy levelling to create a flat surface. However having built a few machines and tried different methods I would get them machined flat but sounds like that might not be an option for you.
NEW MEMBER: Introduction
By routerdriver in forum New Member IntroductionsReplies: 1Last Post: 18-12-2017, 12:03 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
NEW MEMBER: introduction
By woodnut in forum New Member IntroductionsReplies: 0Last Post: 08-11-2014, 04:30 PM -
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
